メインコンテンツにスキップ
2016年6月発売。モデル番号はA3003(EU)、A3000(中国と北米)。(以下の情報より https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/)
Power and volume buttons sunk inside the body of Oneplus 3
So, the power and volume buttons on my OnePlus 3 started feeling a little weird lately and slowly one by one all just kind of sunk inside the body of the phone and stopped working altogether. So, I opened the phone and found that the actual internal buttons were fine and working, but the rubber thingy that pushes those buttons from outside and worn out and was unusable. So, does anyone know if those rubber thingys can be replaced or is there any diy hack to make them work or do I need to get the whole back cover replaced?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
The same thing happened to my notepad..what do I do?
さんによる
コメントを追加
2件の回答
The same thing happened to me a few months ago. The power button went first, and then the bottom volume button some weeks later. I changed my phone battery today and discovered the little plastic bits had basically degraded and crumbled. So now even though my phone is charged up, I can’t get it to turn on and I haven’t seen anything on any forums about what to do about this specific problem. You posted this since 2019, have you had any luck since then? Buying a new phone is not an option for me.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Well, sorry for the late reply. Unfortunately, my Oneplus broke completely before I could get it fixed. The only way to fix this is to replace the complete back housing. So, if you could get a after-market housing, that's the only way to get the phone working properly
さんによる
コメントを追加
There is an inherent fault on the case buttons of the OP3/3T. The Rubber plungers that make contact with the internal ribbon cable button fails over time, it goes hard and brittle, then crumbles. The case buttons need replacing. To do this you require to remove the back case (follow the instructions). Running down either side of the case is a granular adhesive strip. Using tweezers, peel this back carefully until you go past the case buttons. You will see a tiny metal spring clip that tensions the case button in place. Using tweezers again, gently lift that off. You can then push the button from the inside and it will fall out. Then replace with a new button in reverse order.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Vandan Bhardwaj さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 42
今までの合計 715
