メインコンテンツにスキップ
The Acer Nitro 5 AN515-53-55G9 is a laptop targeted towards budget gamers. It boasts 256 GB of storage, Nvidia GeForce Graphics and an Intel i5 quad-core processor at a more affordable price than most gaming laptops.
Wifi adapter keeps dying
So just yesterday I went completely offline and when I checked the wifi settings, it just showed up with no wifi connections and when I hit the troubleshooter, it said there were driver issues, yet it couldn’t fix them. I downloaded and installed the drivers from the acer support website, but it just happened again this morning, is there a way to fix this for good? It’s only just started happening ever since I updated the system to that whole new windows 10 version where everything’s changed and I can’t revert it!
I’m thinking these may be helpful:
Thanks for all the help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @theandroidkid
Try the following:
Uninstall the WLAN adapter in Device Manager
Clear the TCP/IP stack by performing a TCP /IP reset
Restart the laptop.
Check in Device Manager that the WLAN adapter has the latest WLAN drivers installed. If not, then install them
Check if the problem is resolved.
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
Okay, I have tried it, only time will tell if it was successful.
さんによる
okay idk if this would fix mine but it kinda sounded like the same problem for me so I went ahead and did this hopefully I didn't really mess something up but I have bad connection when I move anywhere and it's not my internet or the hot spot so I thought it was my computer plz tell me you know of something else to update on my drivers or something i should do
さんによる
@Cody Kost
It may be a loose antenna connection in the laptop.
if you go somewhere else and you know where the WiFi router is physically located (not easy to know this I know, unless you mean at home) try using the laptop as close as possible to the router. If there 's a good stable connection its looking like an antenna problem.
What is the make and model number of the laptop?
さんによる
I just bought an Acer nitro from a pawn shop and to make a long story short, the wifi adapter (radio) is wore out. I'm waiting for them to fix it but looking at the prices on eBay, I would say just replace the card. It's about as easy replacing memory. The prices I saw were lesss than $15. I was a network administrator in my career (disabled now). I would replace the card before attempting anything with the antennas because on those gaming laptops to antennas wrap around the edge of the laptop itself and it can be a nightmare. Just my two cents. Hope it helps. Good luck
さんによる
コメントを追加
回答を追加する
Bryn Trainor さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 16
今までの合計 1,015
