メインコンテンツにスキップ
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
121回答 すべてを表示
Boots from battery, but not from adapter
Replaced the DC-in board. As soon as I plug in the adapter, the menu bar says "Not charging". It is not an adapter problem - I use the same as the one for my same unit. Logic board?? That would be a shame, since everything else works.
Something did change when I replaced the DC-in: when I press the power button I hear some sort of sound for maybe 2 seconds, as if it were trying to boot, but the sound dies, and pressing the button again does not repeat the sound, until I unplug the adapter, re-plug it, the sound returns on the first press. So it looks like it is getting power from the new DC-in board?
Then I had this thought: Can I do some soldering and make the computer think the adapter is the battery?
Update (08/12/2011)
Don't know how I can add to my answer to my own post? When I submit without typing anything here, I'm told that this field is required and won't let me submit. When I submit with this field filled in, I'm told that I can't answer my own question??
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Try switching the DC-In board to the other machine to verify it.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I can't, took the other unit apart. But I do hear a sound with the new DC-in / see my updated post. Any suggestions?
さんによる
コメントを追加
回答を追加する
sieg deleu さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 3
今までの合計 400
