メインコンテンツにスキップ
カセットプレイヤーの修理ガイドならびにサポート
85回答 すべてを表示
Realistic Ctr-70 play and rewind and fast forward buttons broken
I recently had to replace the belt in the player, but now the play, rewind, and fast forward buttons will not stay down. They still work, but I have to hold them down. Does anyone know how I can repair this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The most common cause of this is that the belt is not placed inside the unit correctly. Without pulling the service manual for this, I can’t easily describe the belt pathway, but this is where you should look. Check the web for a service manual (I haven’t looked). If you can’t locate it, try looking for similar units. The mechanisms for these don’t vary too much and another model may help to show how the belt is run.
If you are still stuck, post your location and someone with experience may be able to take a look and repair it for you.
Dan
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Halley Holm さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 15
今までの合計 111
