Where can I get a USB charging cable for this drone?
I have misplaced the USB charging cable that came with the DX-2 stunt drone. Where can I get a replacement USB charging cable for the DX-2 drone?
Hi,
Did you mean the charger including cable or just the cable itself.
Chargers are available online, here’s an example. Just search for Sharper Image DX-2 drone charger to get results for suppliers that suit you.
Looking at the charger it appears that the charger cable has the standard micro USB connector, so if you have a standard mobile phone charger which has a micro USB connector plug on the cable you should be able to use it to charge the drone.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 22
今までの合計 1,188
