メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2.3L 4cyl or 3.0L V6, 6th Generation
Car dies while driving
I have a 1999 honda accord lx and recently the car has just been cutting off while driving. I can get it to start again but only once it cools down. Is this a possible starter relay issue.? Thank you for any advice you can give.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Probably not the starter relay since that wouldn’t kill the engine. First step would be to see if there’s anything specific that’s happening when the engine dies. For example, is it only after reaching a certain temperature? Or only when turning/going straight/hitting a bump? If it only starts again after cooling down, that indicates it’s a cooling system issue. There might be an overheating problem or there might be an ECU issue that’s misinterpreting temp sensor or other engine parameters. Unless the engine dies at a very specific time, every time, it could be difficult to diagnose without ECU/BCU/engine code reading tools.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Devon Blom さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 469
