メインコンテンツにスキップ
An automatic drip coffee maker, manufactured beginning in 2010, by Mr. Coffee. Also identified by model numbers BVMC-SJX36GT and BVMC-SJX36GTWM.
15回答 すべてを表示
Why is there excessive steam when brewing? can’t see clock!
Why is there so much excessive steam when brewing? So bad we can no longer see clock.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
First check the bottom of the brew basket and the top of the carafe, where the lid pushes up against the brew basket. There’s a “pause-and-serve” mechanism that can get clogged. If it’s clogged or dirty, then coffee doesn’t flow fast enough when its brewing and steam can build up in the brew basket. Also check the top hinged lid to make sure it sits all the way down and seals properly with the top of the housing. Gaps or a loose-fitting lid can let steam escape. Finally, try descaling your coffee maker since scale buildup in the heating element can cause more steam than normal.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Mary Lou さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 34
今までの合計 11,745
