メインコンテンツにスキップ
2018年9月21日に発売されました。モデル番号A2097, A2098、GSM もしくはCDMA / eSIM もしくはナノSIM / 64, 256、512 GB / シルバー、ゴールド、スペースグレイ。(正しい発音は"iPhone 10 S.")
398回答 すべてを表示
I forgot Screen Time passcode on my iPhone, how do I reset my iPhone?
I forgot my Screen Time passcode, I have to erase my device. But I find that I can't reset my iPhone because I forgot the "Screen Time | Restrictions" passcode. Any possible way to remove the forgot screen time password?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 18
4 件のコメント
How did you try to reset the iphone?
さんによる
Call apple, they might be able to help.
さんによる
I just want to rest my iphone to make a new icloud by there's asking Screen Time Password unfortunately i fogot can you please help me to reset
Cheers,
Ghaylle
さんによる
You can use iTunes to erase all data on your iPhone. If this method does not work, you can try to get help from RecoveryTool.
さんによる
コメントを追加
10件の回答
最も参考になった回答
This website should help you
このアンサーは役に立ちましたか?
スコア 5
1件のコメント:
The tool doesn't work - bought it and tried for an hour with no response from their technical team
さんによる
コメントを追加
To erase the iPhone for “forgot the Screen Time | Restrictions passcode “, you can reset it with the following methods:
Method 1: Erase the iPhone with iCloud
You can wipe all personal data and settings from the iPhone and reset the iPhone with Find My iPhone erase function. But the Find My iPhone should be enabled before you go to iCloud. See Apple official tutorial: https://support.apple.com/en-euro/guide/...
Method 2: Reset iPhone via iTunes
iTunes can be a powerful tool for you to reset the iPhone no matter you forgot the iPhone passcode, screen time|restirction passcode or Apple ID passcode. It can help you to do a factory restore, which erases the information and settings on your iPhone and installs the latest version of iOS. After that, the iPhone is set as the new one.
https://support.apple.com/en-us/HT201252
Method 3: Remove the iOS 12 Screen Time Password without Data Loss
For the iOS 12 users, they can benefit from iPhone Passcode Genius as this tool can help to delete the screen time passcode if they forgot the screen time|restriction passcode. They do not need to reset the iPhone and lose all the data and settings. You can check this article to have a view.
For the iPhone reset by iCloud and iTunes, the iPhone users can set the restore the iPhone from backup if they did make one. In this way, they can minimize data loss.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Exactly what I needed, thank you!
さんによる
コメントを追加
If you forgot your screen time password, and you are using macOS Catalina 10.15.4 or iOS 13.4 and later, you can use a new feature to reset your password with an Apple ID.
For earlier macOS, iOS and iPadOS versions, or if you have never set an Apple ID to reset the screen time password, Apple recommends that you wipe and wipe the device, and then set it as a new device to delete the screen time. Unfortunately, according to Apple ’s recommendation, you must set it to a new one.
For iOS 12 users, they can benefit from the iPhone Passcode Refixer because this tool can help remove screen time passwords without resetting the iPhone and lose all data and settings. You can check this article for more information.
https://www.isumsoft.com/apple/how-to-re...
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Some one put this on my phone and now i cant take it off because i need a code, which i don’t know can someone help plsss
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
go to best by geek squad they will fix it for ya
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Hi Jakob Ferris
Reset Passcode
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Forget screen time passcode
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I think a while back I found out a way that if you turn your phone on with the volume and power buttons pushed in then you can reset screen time completely but I did it on like iOS 12-13.
how to: turn your phone off, turn its back on with volume and power button pressed in and hold until you get to the Lock Screen.
If it doesn’t work the first time then try again and again.
I found this out in school cause my phone was loaded with restrictions and so I just crept turning it on and off
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
the $@$* didn't work bruh
さんによる
コメントを追加
I don’t know if this is still a problem or not but if you go to settings and click “change screen time passcode” then click on “forgot passcode?” It should be in blue above the place where you can type in the code. Then you can enter your Apple ID etc. to remove or change the passcode
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If you have an apple id passcode then you can easily change the passcode. If not then try this process this may help you to fix it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Albert Einstein さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 57
今までの合計 95,126
