メインコンテンツにスキップ
HTC Viveのコントローラーは、モデル番号2PR7100で識別できます。2016年4月5日にHTCからバーチャルリアリティ「Vive」セットのアクセサリーパーツとして発売された第一世代のモーションコントローラーです。
Connected but not getting tracked by base station
One day I noticed my controller would occasionally stop getting tracked by the base station and my hand gets stuck in the air in game. Steam Vr said it was still connected.
So I looked some things up and opened it up and unplugged and re-plugged in stuff, I’m pretty sure I put everything back but still had the same result in it being connected but not tracked.
It’s been awhile since I last tried fixing it but now been around longer so maybe there’s a new fix out there.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
4件の回答
最も参考になった回答
Controller is not tracked by one of the base station. One of the 2 lasers of this base station is hard to see or flashing.
Is there any DIY repair for the base stations?
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
In this case the laser diode needs replacing. Unfortunately we don't know an off the shelf replacement for these.
さんによる
Old thread but I just had my light house do a weird noise and my controllers were tracking weirdly suddenly. I figured out that one of the lens glued on the rotating laser felt and I had to put it back on.
You can follow the HTC Vive teardown were they open the light house and check if it looks the same as in the pictures.
さんによる
コメントを追加
Most common cause for the controller to stop tracking or have intermittent tracking is the two ribbon cables from the sensor array that connects to the top of the mainboard back out due to use or hitting walls.
Disassemble the controller and reseat these cables and tracking should return.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks a lot, that was my case, I hit a wall and after that the controller stops tracking, I opened it and those cables went loose as you say, you save me, also I uninstall Gorn after that!.
さんによる
コメントを追加
I was having the same issue and this tutorial was really great at fixing it https://imgur.com/a/hKeB4
need a Torx T3, (T4/T5) personally I used a T4 but everyone says T5
and a 00 Philips head screwdriver. recommend some form of prying devices and some precision tweezers to reconnect the A5 connector
it is possible yours is still connected just loose, mine was fully disconnected.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have followed this guide exactly as shown, the two connections that are usually unplugged/loose was fully connected, I disconnected this and reconnected it still having the same issue. Note I completely took a part the saucer to examine if any sensors were damaged and everything looks as should.
さんによる
コメントを追加
I had a similar issue with mine. It was caused by intermittent interruptions from my USB drivers. Try updating your USB drivers. Also, if your motherboard is older and doesn’t have function well with 3.0, try plugging it into a 2.0 port. I know 3.0 is suggested, but plugging it into 2.0 may fix your issue if that’s what is causing the problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Tech Nich さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 44
今までの合計 2,904
