Why are my clothes still soaking wet after the washer runs it cycle
Have a front load refrigadare washer the clothes are still soaked after washed … but if u turn the knob to the spin cycle they spin out ! What could be the issue ?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The most common issue is:
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not drain. To determine if the lid switch assembly is defective, use a multimeter to test each of the lid switches for continuity. If a lid switch does not have continuity, replace it.
\Here's how to bypass it until your new part comes in: https://www.youtube.com/watch?v=j8rrZIxA...
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 226
