Why my iPod got hanged
Hi, My I POD Classic got hanged, my mistake was I took it from the laptop without ejecting properly,
Now please help me to get rid of this problem,
Venkat Kumar M Try to reset your iPod according to the Apple instructions:
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try resetting the iPod while it is connected to power.
Let us know how it is going and if this worked. If it does not let us know exactly was is going on with your iPod. Good Luck
このアンサーは役に立ちましたか?
thanks for the advise but it doesn't work, now even my iPod is not getting started
Regards
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,450
