メインコンテンツにスキップ
Smartphone designed by Xiaomi in the Redmi Note line.
56回答 すべてを表示
battery is emty .cherging is not happeninng and battery gone dryied
sir my redmi note 4 is not openinng .i replaced with new battery but worked till the battery is emty .cherging is not happeninng and battery gone dryied and mobile is not opening. its totally gone dead . when put charging only red light is blinking and not openging. i showed mobile local service man he tolled display is gone and toled to replace the display. pls guied me to solve the problem. im helpless
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
vasanth kombettu  this “replaced with new battery but worked till the battery is emty” shows that your phone is not charging. It has nothing to do with the dispaly. Your phone will need a new USB charging port at least. It is possible that this is also caused by a bad charging circuit but for now, start with a new charging port. something like this will be the start to fixing your mobile phone.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
vasanth kombettu さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 10
今までの合計 63
