メインコンテンツにスキップ
JBLによるFlip ポータブルスピーカー第3世代の修理とサポートガイドです。
70回答 すべてを表示
My jbl flip 3 fell in to water and won't turn on.
About a month a ago i accidentally fell my jbl flip3 into water and unfortunately water went inside it through the usb port and aux port. it worked for the couple hours but then it stopped working . it wont charge and turn on. please help with a solution.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @tanvir231161
As you know water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the speaker's operating design and could damage the components.
First do not turn on your speaker and then you need to remove the battery as soon as possible from the speaker to minimize further damage.
Then you need to dis-assemble the rest of the speaker and clean all the affected parts using Isopropyl Alcohol 90%+ (available from electronics parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and is not as effective. If you do check the label to verify the amount of IPA
Here is link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the speaker might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing your speaker.
JBL Flip 3
If this process seems too daunting, take your phone to a reputable, professional electronics repair service and ask for a quote for a repair. If you decide to do this, do it sooner than later.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Tanvir Ahmed さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 22
今までの合計 560
