メインコンテンツにスキップ
The fifth-generation Elantra debuted at the 2010 Busan International Motor Show in April 2010. The fifth-generation Elantra (2010-2015) added a two-door coupe variant in addition to the standard four-door sedan model. These Elantra vehicles included six-speed automatic or manual transmissions.
20回答 すべてを表示
One of my low beams doesn’t work on my 2014 Accent.
Was about to buy a new light bulb than noticed that it worked. This morning started it up and it was out again. Tapped the light and it turned on. Now is back out. Tapped it but still out.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hi @creestuff204 ,
It sounds like either a faulty bulb, bulb socket or a loose wire in the socket connector perhaps.
Here’s a link to the owner manual for the vehicle.
Scroll to Sect. 7-76 to view how to change the headlight bulb. This will let you inspect the bulb, the socket and the wiring.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
the harness that plugs into the back of the bulb will be loose, a washer or seal may have perished and is preventing it from closing tight. other issue would be the wire pin in the harness itself is loose.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mike jones さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 66
