メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
iPhone 7 vertical lines
Hi all
Have here an Iphone 7 which was dropped in the bath (kids!!) took it apart and cleaned motherboard amongst other parts with osyprinal and replaced the screen, all cam back to life and no issues for a few months, until now she dropped the phone which did not damage the screen in any way, however the screen is showing lines now, touch still works, I have changed the screen to see if that would sort it out but still with the same issue, see attached.
Any pointers would be appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Remove any power from the phone (including the battery) it could be that there is corrosion in connectors due to the water or it would be you damaged the pins when you plugged in the screen, corruption can be cleaned with alcohol and a toothbrush and if there is a bent pin you could try ending it back but most likely you need to replace the connector which required soldering and it’s a job for a professional
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
colin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 3
今までの合計 59
