ONN 50” Tv NO PICTURE
When i turn on my tv, the sound from the playstation will work but there is no picture or display. can anyone point me in the right direction. it worked fine the night before last.
Sydney Chandler try another input source. As a matter of fact, try all different ones. You said you can see it with a flashlight but not without? If so, then this is mainly a backlight issue. You’ll have to take the back cover of your TV and have a look at the voltages from your power board to the backlight LED’s as well as the main board. We would need to know your TV’s exact model and possibly see the boards etc. Once you remove the back cover post some good pictures of your boards etc. with your QUESTION. iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
model number ONA50UB19E05 (H19004-JX)
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 5,753
3 件のコメント
when i put a flashlight to the screen it shows “no signal press input” blah blah blah
Sydney Chandler さんによる
I have a 70 in ONN , you can't see it with a flashlight and there is a volume but cannot see the screen.
I need help
William Sye さんによる
@williamsye depends on your exact model. could be a bad T-con board, bad main board or worst case a bad panel.
oldturkey03 さんによる
