My tablet is at zero percent what do I do
Won't turn on been charging for 3 hours and it charged my dad's phone but won't charge my tablet
Robert Taylor check your charging cable and try a different AC adapter. Your tablet may require a higher amperage. If all that checks out then you need to check the charging port, Clean it with a few drops of 90%+ isopropyl alcohol and a few puffs of compressed air. If that does not change anything you may have to disassemble your tablet and check the charging circuitry for obvious damage and change the battery as well.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 117
