メインコンテンツにスキップ
Repair and disassembly information for the Samsung 55" UHD television with model numbers UN55MU6290xxxx. Released in 2017.
57回答 すべてを表示
65” Samsung Curved got coffee spilled on it
My TV is actually model UN65MU6500 coffee got spilled on it and now it just turns on and off with a black screen. It acts like it wants to come on then goes back black. And just keeps repeating over and over.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Kyron Perks  at this time you want to stop trying to turn it on. Unplug it and do not use it. The constant on-off attempt can make an already bad situation worse. Remove the back cover from your TV and check the boards and interconnect cables. You should notice any coffee stains etc. you also need to check the top of the panel. that is where the LCD boards connect to the panel via some very fine ribbon cables. Depends on what got “soaked” you may need new power board etc. but we would need to see what your boards etc. look like. Post some good pictures of everything with your QUESTION iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Kyron Perks さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 135
