メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年9月19日に発売されました。この5.5インチサイズのスクリーンをもつiPhoneは、iPhone6の拡大サイズ版です。
touch problem and sim searching
My friend broke the screen of his iPhone . After the drop the phone would not open, so I changed the changed the screen and i factory reset it. Sadly i noticed that it didnt work, so I took the screen back to the store and they gave me a new one.After I switched the screen with the new one, its touch would still not work. I also put my sim card in the phone and it was searching non stop. what can I do?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
These symptoms are typical of an IPhone 6 plus. The no touch would be a broken trace under the touch IC “Meson” This is fixed by lifting Meson, running a short jumper wire and replacing Meson.
The “searching no service” would be caused by a broken trace under the “baseband CPU” This is a lot more difficult to repair.
These faults on the IPhone 6 plus are caused by a drop and or flexation. As the IPhone 6 plus is getting on in age it might be more economical to upgrade.
このアンサーは役に立ちましたか?
スコア 2
9 件のコメント:
I found that if i change the U_QPOET it will work. Is it right? Because the problem is the "searching"
さんによる
I have never found the (Qpoet) responsible for the “searching no service.” It has always been the baseband on the 6 plus. You can confirm this by imputing “*#06#” on the keypad, if no IMEI number comes up it is the baseband CPU.
さんによる
I went to settings and i found the IMEI number. If i inputed on the keypad the number it didnt appear anything
さんによる
https://youtu.be/icy4qBbkCFY . I have normal IMEI and ICCID
さんによる
If the IMEI didn't appear on the key pad you have baseband problems. The IMEI is memorized in the settings so don't take any notice of that. The only other way to check would be to flash the IOS with 3UTools and see if it still has an IMEI number in settings.
さんによる
4件以上のコメントを表示
コメントを追加
回答を追加する
Stelios Karagiorgis さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 14
過去 30 日: 18
今までの合計 167
