メインコンテンツにスキップ
iPhoneの第2世代モデル。モデル番号はA1241 / 8 もしくは16 GBの容量/ ブラックもしくはホワイトのプラスチック製背面ケース。修理はオリジナルiPhoneに比べて直接パーツに作業ができます。ドライバー、こじ開けるためのツールと吸盤カップが必要です。
1158回答 すべてを表示
Sound adjustment rocker bar missing
I gifted my old 3G to my grand daughter. She was able to shatter the front glass and somehow, either in that process or in another removed the rubber like sound adjustment bar from the side. Replacing the glass and digitizer is doable and inexpensive, but I can't find any reference to how to repair the sound rocker switch. I haven't yet taken it apart, there's just an empty slot where the rocker used to be. I had taken this unit apart and put a new battery in it about a year ago so I'm not afraid of doing the take down.
TIA
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
That switch is actually attached to the iPhone Back Assembly and is pretty hard to fix without replacing the entire back assembly itself. You could try buying a new button and superglue it back on, however there are many things that could go wrong with that (putting too much glue on and rendering the button useless all together with possibility of glue leaking inside the assembly and damaging the ribbon).
If i were you i would just buy a new back assembly and be done with it. They are fairly cheap and easy to install, and if you have already replaced the battery once you will know how to do this easily.
You will want to buy the "Back Cover Assembly " to save the hassle of installing all of the components that go into the assembly itself. A quick google search should find you a decent price.
Hope this helps! :)
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
dheady さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 2
今までの合計 702
