What is this rubber ring?
Hi all.
I have changed the drive on a HP y0a95ea#uuw.
But I have a black rubber ring what is that for?
Thanks.
Regards Daniel
usually, with hard drives, they use little rubber things like the one you have to reduce vibrations in the mount of the hard drive. It probably fits in somewhere around the mounting mechanism for the hard drive.
I imagine it would go go in one of the circled areas.
このアンサーは役に立ちましたか?
Hi. Thanks for that. I only have 1 but I have switched to ssd so i think All good but meny Thanks
過去 24時間: 0
過去 7 日: 8
過去 30 日: 10
今までの合計 144
Hi @danielpt I tried looking up the model number you gave, and I can't find anything. could you double check your model number? https://support.hp.com/us-en/document/c0...
Aiden さんによる
I think I found it. apologies.
Aiden さんによる
