メインコンテンツにスキップ
Released May 2015, identified by model number SM-T350. Features 8.0″ TFT capacitive touchscreen, 5 MP camera, Wi-Fi, GPS, Bluetooth.
Screen brightness resets after restart
I have a Galaxy Tab A 8.0 SM-T387 that has a brightness issue. After I start it up, the brightness is all the way down on the dimmest setting. I turn it up and it stays up, thankfully, but when I start it up again, the brightness is all the way back down again. Is there a way for me to force it to keep the brightness where I put it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi,
After you have adjusted the brightness setting, re-start the tablet in safe mode and check if the setting is still correct.
If it is then a downloaded app may be the cause of the problem.
The trick is to find out which one is the culprit.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
godingservices さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 1,550
