メインコンテンツにスキップ
2014年9月9日に発表されたこのデバイスはAppleが進出した最初の身につけるスマートデバイスです。iFixitの修理マニュアルではApple Watch (スティール製)とApple Watch Sport (アルミニウム)どちらも対応しています。
210回答 すべてを表示
No display after screen and battery replacement
I recently ordered from iFixit three items to repair my apple watch. Battery (just was not holding a long enough charge), force touch sensor and used sapphire screen (screen was shattered from a three foot unlucky angle drop). After installing all three without any issues (no torn cables, took about 30 minutes), I get no display.
When I charged my watch for about 1 hour the battery gets warm (the actual battery not the whole watch). Seems about as warm as is normally the case. I have tried putting the old screen on and the old battery back in with no luck. I have tried hard resets (holding crown and side button for up to a minute) . Nothing is working and nothing looks even slightly damaged. Am I out of luck? I throughly read through iFixit instructions before starting.
This is the first gen device. Series 0 or revision 1. As a side note I have successfully repaired at least ten iPhones; screens, batteries, cameras and even a proximity sensor (very small parts). One time I even tore apart a water damaged iPhone 4, cleaned all the parts, including the logic board with isopropyl, and had it running for a year.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
1 件の回答
最も参考になった回答
Did you disconnect the battery when plugging in the screen? I know you can fry iPhone screens if you plug in the screen after you plug in the battery. Do you have a slave display you can check the watch with? Does the watch show up as connected to your iPhone when it gets warm?
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
As per the instructions on iFixit I did first disconnect the battery. I have tried the old screen (which still worked, but is badly cracked) with no luck. The iPhone 8 plus does not detect the watch at any point. Thank you for your response.
さんによる
I have recently installed a new battery and a new screen to a 1st gen stainless steel Apple Watch, too. The watch gets warm and the screen doesn’t respond. Maybe the screen is the issue?
さんによる
コメントを追加
回答を追加する
Leon Ewell さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 16
今までの合計 700
