メインコンテンツにスキップ
The 15-BS008CA is a budget laptop released by HP in 2018.
My laptop Turns off suddenly and battery is over 20%
When I leave my laptop it suddenly turns off without warning. When I try to re open it… the bios settings are defaulted everytime
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi,
The BIOS settings defaulting when the laptop is off indicates that the RTC battery is flat (no pun intended - it is a coin cell battery) and it needs to be replaced.
Here’s a link to the service manual for the laptop taken from this webpage.
Scroll to p.59 to view the necessary pre-requisite steps and then the procedure to replace the RTC battery. You’ll also find the part number for the battery 922847-001 there. Although usually the battery type is printed on the battery itself and it is a commonly available type.
Your main battery may also be failing to hold its’ charge when at a low value.
After you have replaced the RTC battery check to see what happens as far as shutting down unexpectedly goes. If it still occurs you may have to replace the main battery. Part numbers and procedure on p.34 of the manual.
Since you have the laptop open to replace the RTC battery also check that the fan and air vents are not clogged with dust, preventing good airflow over the CPU
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Ahmed Zaglool さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 8
今までの合計 214
