メインコンテンツにスキップ
Device repair and information for the Dell Alienware 15 R3, a gaming laptop in the Alienware series.
Screen flickering right part of the screen
Hello , I have a problem with my laptop i don’t know what cause this problem and i just wanna know if this a software problem or hardware problem maybe cable or the entire screen is now broken
here is the video showing the screen problem Video 1 Video 2
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
Try connecting an external monitor to the laptop and check if its display is OK.
If it is then you may have a hardware problem.
It could be a loose video cable connection to the systemboard, a faulty video cable (trying pressing on the left hinge area to see if you can make the problem come and go) or a faulty LCD panel.
Here’s a link to the service manual for the laptop.
Scroll to p.85 to view the necessary pre-requisite steps and then the procedure to remove the display assembly.
This should give you access to view the cable connection first.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Amr Fakhri さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 1,535
