メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル A1001 または A1025 / 667 MHz、800 MHz、867 MHz、または 1.0 GHz G4 プロセッサ
Excessive Fan noise after being on for a while?
I wanted to know if this is a known issue and what I can do about it. The fan is really working overtime and it is hard to work when hearing that noise. Also, I don't want this thing to catch on fire if it is possible for that to happen.
It is a Powerbook 867 titanium model. thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
is there a guide on how to replace the thermal paste on this powerbook?
さんによる
コメントを追加
2件の回答
ベストアンサー
My bet would be that the vents are clogged and the thermal paste needs replacing on a machine of this age. I would tear it down, clean the vents and replace the thermal paste. Here's how to get to the heat sink: PowerBook G4 Titanium DVI ロジックボードの交換
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
When you open it up you will find apple in the titanium laptops have used the worlds smallest internal cooling fan (1cm x 1cm of actual fan blade airflow area). Also pointing in a wierd relation to the vent it sits next to , the thermal design on this laptop could not have been much worse from a design perspective, except say a bare chip ? I have replaced the thermal paste on mine neatly and precisely with top quality thermal paste it makes very little difference, as the poverty of design revolves around an inability to push the hot air out of the laptop, again another example of form over function, this laptops micro fan will kick in hard with no heavy load straight after boot up. The only way to correct excessive fan noise on the titanium models would be to completely re-design them. They are flawed by design.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Yuri さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 16
今までの合計 1,837
