メインコンテンツにスキップ
The Gateway FX6840 is a desktop PC that features an Intel Core i7 processor.
5回答 すべてを表示
Windows 10 won't boot due to drives converting to RAW format from NTFS
How do I convert RAW drives back to NTFS without losing data. Windows 10 repair options during reboot can’t fix. Only access is through the comand prompt. Have not tried diskpart option to convert to NTFS because of worry that I will lose data. All three partioned drives have all been converted to RAW format!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
If I am not wrong, RAW format on Windows means that is part of a Software Array or Dynamic Disk Array. If you can see your information on CMD backup your information to another drive and make a clean installation.
If a drive is bad and is part of an Array you have to replace it and rebuild the array. If everything has been made with windows you can try to boot from another hard drive with windows and see if you can rebuild or backup your information.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
David Spear さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 205
