How can you load games without the disc
it needs a disc
この質問は役に立ちましたか?
Checking the specs on the Advent Netbook I find it has three USB ports. Just buy an external dvd-drive that connects with usb and you should be good to go. This is a very basic unit so I hope the games you want to play don't require a lot of computing power.
http://www.newegg.com/store/SubCategory....|dvd%20drives|external%20dvd
このアンサーは役に立ちましたか?
Just you can't.
If you can't buy an external USB DVD Unit, look if you have a friend with a computer with internal or internal DVD ROM, tell him if can copy entire DVD or CD inside an usb pendrive.
Then you should be able to use almost 90% of the games (except those with protection system in the media)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 8
今までの合計 442
