メインコンテンツにスキップ
This guide will enable you to be able to repair any issue with your PowerBeats3 Wireless Earphones
39回答 すべてを表示
they said the battery is ok, but I need to the machine near the volume
The battery won’t charge, sometime it’s charging but it won’t last long when i use it only less then a hour
The repair shop said the battery is fine, but i need to change the machine near the volume button?
what should i do ?
at repairing shop they trying to to fix by replacing the machine with the fake one but i refused and choose to wait the better solution
Please you have any solution or the trusted shop to fix it in Jakarta (indonesia)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Oman Muji all of this “The battery won’t charge, sometime it’s charging but it won’t last long when i use it only less then a hour” would make me replace the battery no matter what the repair shop says. I wondered how they tested the battery since it will require a load to show how long it will last. A simple things to do would be to use a USB ammeter when you charge and see how many amps it draws. If it does draw then it is not anything else but the battery. Start with that first.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Oman Muji さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 79
