メインコンテンツにスキップ
Product Dimensions: 6.3 x 3.1 x 6.3 inches Item Weight: 7.8 ounces Item model number: 04091378 Released: February 2016
What battery type is in Marshall Major 2 Bluetooth?
I’ve been using Marshall Major 2 Bluetooth for 22 months. Recently the headphone stopped charging — instead of blinking red light when plugged in, I see a very dim solid white light. I searched in forums and apparently several other people had the same problem. Somebody recommended (aside from the 12-month warranty) replacing the battery.
Is it okay to replace the non-working original battery with an average Lithium Polymer battery? It says somewhere that the original batteries are 680 mAh.
Update (11/11/2019)
Hi @oldturkey03, so I have bought a LiPo battery, but turns out it’s without NTC. The original battery inside the headphone has NTC.
Can I just omit the NTC connection?
The connection inside the headphone:
The battery I bought:
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
10 件のコメント
@gizatm personally I would not. NTC is what can keep your battery from overcharging etc. I am not sure if your charger etc. would recognize when to stop charging etc. It might work temporarily but I'd be a little leery and would try to find one that gives me that extra little bit of protection.
さんによる
@Coding Tintin  I have the same problem.Is it fixed with the battery you bought ?
please answer.
さんによる
@Arman Mkrtchian, unfortunately, not yet. If you look at the image, the battery I bought has only two cables. The Marshall headphones require the third one for NTC. So now I need a battery with three cables. Right now it's not fixed.
If you do fix it, please, write here. Currently I can't find the battery on Alibaba. Might need to look at Amazon.
さんによる
@Coding Tintin ok, I will write.
さんによる
I have found something like this, and it does look like it should be working like a charm!
I have just ordered it, so it will take a while, to give my review.
https://www.aliexpress.com/item/32996928...
さんによる
5件以上のコメントを表示
コメントを追加
2件の回答
ベストアンサー
@gizatm yes it is for as long as the voltage is the same and the physical size will fit. A lower mAh or greater mAh just means that you may have to recharge the battery faster/lesser.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Thank you, I will try fixing it myself with this method.
さんによる
コメントを追加
Did you manage to fix it?
Got the same problem
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Coding Tintin さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 13
過去 30 日: 34
今までの合計 10,577
