メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Device repair information for the 1080p 60" Projection TV by Mitsubishi with model number WD-60737.
My tv do not on, only have red light blink 6 times and yelow light 1?
the red light blink 6 times and yellow 1 time it has repair.?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
7 件のコメント
I have a mitsubishi 76” color television set WD - 73C12 that blink 6 red and 1 yellow blink. Is my television repairable and will it be expensive to repair?
さんによる
The exact same thing just happened on my Mitsubishi projection TV. Mine is 12 years old, model WD-73738. This is the third bulb to burn out. Front light is blinking 6 red and 1 amber.
さんによる
Mine is a- WD-82C12 82 inch DLP TV Mitsubishi it’s 6 red blinking lights and one yellow blinking light
さんによる
@teresalynn51796 for your model it's the same thing. That particular error code tells us that the lamp isn't energizing and possible failures are either that the lamp isn't installed correctly or that the color wheel in the light engine isn't spinning (broken or jammed) or that the light engine circuitry has failed. Does that help you enough? If not then we convert this into its own question and get more into the details.
さんによる
My Mitsubishi WD-82738 82in blinked 6 times red and 1 orange what does this mean
さんによる
2件以上のコメントを表示
コメントを追加
1 件の回答
最も参考になった回答
Exequiel Martinez  double check the code. To get the error code, after the tv tries to turn on and fails (blinking red led), go up to the front panel press and hold ACTIVITY + CH DWN until the led starts blinking in a repeating pattern. let us know what you get. What you originally have is a code 61 which is a No Lamp Enable which is received at the DM and Ballast. So this could be an issue with either the fans, the color wheel or the lamp. Let us know if the fans spin, and if the color wheel spins.
Here is the service manual that should help you repairing your TV Mitsubishi WD60737
このアンサーは役に立ちましたか?
スコア 4
4 件のコメント:
I think it's the color wheel, because the color is not clear.
さんによる
OK I dud what you said but all I get is 6 blinking red and 1 orange lights
さんによる
Should I try using the bulb I have an extra one here
さんによる
@charlesehawkins might as well since you have a spare readily available
さんによる
コメントを追加
回答を追加する
Exequiel Martinez さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 61
今までの合計 4,566
