メインコンテンツにスキップ
Guides and repair information for washing machines produced by Bosch, a German engineering and technology company.
21回答 すべてを表示
Bosch Nexxt 800, how do I get it to drain so I can open the door?
I read the useful thread on why Bosch Nexxt washers might get blocked drains. But is there any way to get it to drain manually now so I can get the clothes out, and get the door open, before I start looking at the various reasons it might be blocked? I’m assuming it’s a bad idea (or just un-necessary) to start working on it with door locked and full of water and clothes.  Do I then remove the lower front panel to get in a check the coin trap, the drain pump, etc.?
Bosch Nexxt series washer won't drain..
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
@stw yes, you do want to drain it first. Remove the lower panel and you can drain your washer from there. Careful so, there is going to be a big watery mess coming at you. Get a shopvac and lots of towels ready; there will also be quite a stink coming from the drain ;-). You’ll also find a green marked door latch cord that you can pull to release the front door. You have not told us what is going on with your washer and what you have tried. I would always start by running the diagnostic program
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Here’s my previous answer on this:
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
On the front is a trim under the load door.
Mine is gray. It pops right off with your fingers. Under it is a round door that screws off. Inside of the is an emergency release pull for the
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
mitch harris さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 19
過去 30 日: 70
今までの合計 2,205
