tv only have sounds after a HDMI has been connected
why does my samsung 60 in tv has sounds after I connect a HDMI? And why is there sounds, but no picture
@daflex verify that your TV is a Samsung 60" LED TV UN60FH6003FXZA What have you tried to fix this? Tried a different cable? Until we know what is going on you want to try the basic. REmove all inputs from your TV (that includes cable/sat box/ game console etc.) Unplug your TV. Hold the power button depressed for something like one minute or two. After that connect only one video input source (preferably as local source like a DVD, BR or game console) Then plug your TV in and start it up. Let us know what you get. It would be very uncommon for this to be a bad panel but it could be the main or T-con board (depends on the model etc.)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 101
1件のコメント
I bet you've tried the obvious things like changing the input, but when you change the input, do you get any feedback that the display is functional? For example, do you see "HDMI 1" or "HDMI 2" when you switch inputs? If not, this may be a sign that your display is busted. You should at least get some sort of screen feedback.
Alex Robinson さんによる
