メインコンテンツにスキップ
Repair information and troubleshooting for the HP Pavilion 15-au. This is a 15 inch laptop computer manufactured by HP as part of their Pavilion line.
7回答 すべてを表示
Why does my laptop power light flash 3 times but not turn on?
I have a hp pavilion notebook 15-au181na laptop. When I push the power button the light by the place where you plug in the laptop charger flashes 3 times but does not turn on.
It all started when I was trying to reinstall windows 10 using a USB. This is because I had to replace my laptop bottom case and keyboard because the old ones were cracked and I had to remove the mother board, battery and hard drive and then put them back in. When I did this then the computer would not boot up and therefore I had to reinstall windows 10 using Rufus and a USB.
I have tried removing the battery and then pushing the power bottom for 30 seconds however, it has not worked. I also tried plugging in the power without the battery and this also has not worked.
Does anyone know why my laptop will not turn on?
Thank you if you can help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I had this recently on another HP and it turned out to be a faulty hard drive. According to the HP website that is faulty hardware and the laptop should be returned to a HP service center.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
A019 さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 49
今までの合計 958
