メインコンテンツにスキップ
2018年7月に発売された、モデル番号{A1989 / EMC3214}のMacBook Pro13インチモデルにはクアッドコアi5と i7 を搭載しており、グラフィックにIntel Iris Plusが統合されています。
199回答 すべてを表示
No option for "Adjust keyboard brightness in low light"?
I recently replaced the display on a MacBook Pro (13-inch, 2018, Four Thunderbolt 3 Ports) with Touch Bar and now the keyboard backlight is not adjusting automatically in low light. I’ve tried manually adjusting the keyboard backlight and there is no response. When I got to the appropriate system preferences for the keyboard there is no option for me to check or uncheck “Adjust keyboard brightness in low light“. It just lists the options “Touch Bar shows [Expanded Control Strip]“ and “Press Fn key to [Show F!, F2, etc. Keys]“. Has the keyboard backlight somehow been disabled, or could this be a result of a defective display? Thanks for any help you can provide!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
4 件のコメント
Where did you get the display and the P/N you ordered?
さんによる
@danj Part number is 661-10037 purchased from la.tronics through eBay.
さんによる
Did you ever resolve this issue changed my screen using same supplier now no keyboard brightness. ?
さんによる
We eventually determined that the display we received was incompatible. We replaced it with a separate known-good display from a same model machine and the issue was resolved.
さんによる
コメントを追加
1 件の回答
ベストアンサー
While the part number you supplied is the correct one for the 2018/19 models I fear you got a 2016/17 model by mistake!
You’ll need to return it and either get a replacement or your money back to get the correct part from a better source TheBookYard - 2018/19 MacBook Pro 13" Complete Display P/N 661-10037 Vs TheBookYard - 2016/17 MacBook Pro 13" Complete Display P/N 661-07971
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
This shows the 2016/2017displays as compatible with the 2018/2019 models. Is that incorrect? It does list a different part number though. MacBook Pro 13" Retina (Late 2016-2017) Display Assembly
さんによる
They are not! Trust me I had the same issue! I've posted an update to the iFixit store for the correction in there listing. They have been out of stock for a while which is why I had pointed you to TheBookYard.
The BookYard lists the 2016 & 2017 as compatible with each other. It does not list the 2018 & 2019 models as compatible with the 2016 or 2017 at all.
さんによる
2018 MBP model is the 1st with HDR, so a 2016/2017 model would be a step backward.
さんによる
@David Smith - Some slight corrections:
The 2018 and newer models offer TrueTone were the backlight color temperature is shifted depending on what the FaceTime Camera sees for the lighting of the room on the internal display.
The internal display does not support HDR! You require an external display which offers it!
Here's more on the details: Play HDR video on Mac
さんによる
コメントを追加
回答を追加する
Zach さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 3,722
