メインコンテンツにスキップ
7.9インチのディスプレイ、モデル番号A1432、黒と白色のモデル、発表日は2012年10月23日、サイズは16、32、64GBがあります。
220回答 すべてを表示
Impossible to use wifi on Ipad mini
I bought a ipad mini on facebook marketplace and the kid told me the wifi was hardly working. I only paid $20 for it and after trying everything in my power to get the wifi to work, I came to the conclusion i need to open it up and replace a part. The ipad will not detect my home wifi and i can only connect it using my phone hotspot if it is touching my phone. Sounds like a faulty wifi antenna, doesn’t it?
Is there any other part in the ipad that could cause terrible wifi connection apart from the wifi antenna that i’m finding on amazon prime for $5-$10? I have no experience in fixing devices but wanted to give it a shot, seems like something I could do.
I have also noticed a small crack in the screen, I found a replacement on amazon for $15 so I decided i might as well grab that and replace that too, but my main question here is that I just want to verify that it should be the wifi antenna I should be replacing.
Thanks! -
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Well I had a similar problem with my iphone X and I fix it with out replacing anything. What you want to do is go to the settings and general and rest then reset your network settings. If that doesn’t work go on a computer install the newest verion so it can replace and repair the IOS. Create a backup and reinstall the base OS and the put the backup back on it.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Doesn't seem to be the case here. The ipad is completely formatted and is up to date according to itunes. Parts came in just now, will attempt to fix it tonight.
さんによる
@ethanwit do you have a result
さんによる
コメントを追加
回答を追加する
Ethan W さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 25
今までの合計 252
