メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年10月26日にリリースされた第4世代のSurface Proタブレット。
Surface pro 4 screen replacement
Hello, i’m new here.
I would like to ask you if you could tell me which screen is mounted. I read that there are two versions and that the sp4 tablet is born with the Samsung screen. Subsequently, due to flickering problems it appears that the screens have been replaced by LG screens.
below I post a picture.
I would also like to ask you if the model in ifixit is compatible with my device and that I avoid the flickering effect
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Hi pisanivito,
I believe your broken display is an LG sourced display. I have attached an image of a Samsung display. The differences are subtle and they are interchangeable, provided you use the correct connectors. If you choose to use the IFIXIT display, it will be compatible with your Surface Pro 4, but you will need to order the correct display connector PN: X937072-001 . The N-Trig Digitizer should just be a hot-swap and although your connector for that looks different from mine, it should work with a Samsung display just fine.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi Logan, pianivito,
I am doing the same upgrade myself. M1010537-003 is the correct part number for the LVDS display cable to upgrade a Surface Pro 4 to a newer LG display. Cable X937072-001 is for the Samsung unit in your screenshot
Cheers, Neil!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
pisanivito さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 16
過去 30 日: 41
今までの合計 858
