メインコンテンツにスキップ
2018年10月26日発売。モデル番号はA1984, A2105, A2106, A2108。オプションとしてGSM もしくは CDMA / eSIM, nano-SIM もしくは dual-SIM / 64, 128もしくは 256 GB /カラーバリエーションはブラック、ホワイト、ブルー、イエロー、コーラル、レッドがあり。(正しい発音は"iPhone 10 R"です)
468回答 すべてを表示
iPhone XR Mainboard Replacement
Hi all,
i have a good conditions iPhone XR but the mainboard is locked. It is possible to replace the mainboard with another one of an accident iPhone XR?
Does the Face ID have a correlation with the motherboard or can I keep what I have on my phone now and replace only the MB?
Thanks a lot.
__________
Ciao a tutti, ho in buone condizioni un iPhone XR ma la scheda madre è bloccata. È possibile sostituire la scheda madre con un'altra di un iPhone XR sbloccato e incidentato esteticamente? Il Face ID ha una correlazione con la scheda madre o posso mantenere ciò che ho sul mio telefono e sostituire solo l'MB? Molte grazie.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
The motherboard, Face ID sensors and the earpiece all must be transferred in order to Face ID to work.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
You are opening up a can of worms. ios13 trips a lot of warnings. You should replace the lcd assembly, all cameras, battery, logic board and vibrator. All those parts are coded to the logic board.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
While it is doable, it is a lot of work. Apple has serialized a lot of the components in the iPhone such as the battery and display assembly, which will pop up with a message that says, “Apple was not able to verify if this is a genuine screen/battery.” Also you’ll have to have the corresponding FaceID components for the board such as ear speaker and front camera assembly. For the amount of work it’s gonna be, sell that phone for parts and buy one that doesn’t have a lock on it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Skeggia さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 11
今までの合計 634
