Replacing DaughterBoard in HP
Hi-
I need to replace the daughterboard on an HP 14-df0023cl Motherboard i3-8130U PH675. I can’t find a replacement online. Are there any compatible devices I could use?
Hi,
What daughter board are you referring to?
Here’s a link to the service manual for the laptop taken from this webpage
In the manual you’ll find the part numbers for the various “board” components in the laptop.
Search online using the part number only in the search term of your browser to see if you get results for suppliers of the part.
e.g. the USB board part number is L24483-001. Searching online using the part number only, produced these results.
Here is a list of all the boards and their part numbers (except the systemboard) in the laptop if you have problems downloading the manual.
TouchPad board L24484-001
TouchPad click board L24486-001
USB board L24483-001
eMMC board (use for 2nd solid-state drive installation) L23397-001
Solid-state drive board L24487-001
WLAN Dual antenna:
Intel Dual band wireless-AC 3168 802.11AC 1×1 WiFi + BT 4.2 Combo Adaptor (non-vPro) 863934-855
Realtek RTL8822BE 802.11 ac 2×2 WiFi + BT 4.2 Combo Adapter (MU-MIMO supported) 924813-855
WLAN Single antenna:
Realtek RTL8821CE 802.11 ac 1×1 WiFi + BT 4.2 Combo Adapter (MU-MIMO supported) L17365-005
Realtek RTL8723DE 802.11 bgn 1×1 WiFi + BT 4.2 Combo Adapter L21480-005
Intel Dual Band Wireless-AC 9461 802.11 AC 1×1 WiFi + Bluetooth 5 Combo Adapter (non-vPro) (MU-MIMO supported) L25889-005
Memory module:
4 GB 862397-859
8 GB 862398-855
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 4
過去 30 日: 9
今までの合計 633
