How to upgrde this laptop with gtx1660ti ,8gb ram and 2tb ssd.?
I want to upgrade my laptop (Dell latitude E4310) with 2tb ssd,8gb ram and gtx1660ti.
can I do it?how to upgrade this laptop with thtis specifications(2TB SSD,8GB RAM,GTX1660ti)?
Hi @aslam44 ,
You can upgrade the RAM to 8GB as the laptop has two memory slots that can each handle 4GB PC3 8500 RAM modules.
You can replace the HDD with an SSD. Here’s a video that shows how to do it.
You cannot upgrade the GPU as it is hard mounted onto the motherboard.
Here’s a link to the service manual for the laptop which may help with the replacement of the RAM and the HDD
このアンサーは役に立ちましたか?
thank you very much..
i want to use an external gpu for my laptop..
Would be cheaper if you bought a Ryzen 5 Laptop with a GTX graphics.
As already mentioned by jayeff, the ram and storage upgrades are very much possible. You can choose to buy an eGPU device to use your graphics card with the laptop, but I wouldn’t recommend this unless you already own the card and have $40-50 to spare. The eGPU adapters can connect with Expresscard or mPCIe, but either one will work okay. Of course, your graphics card will be slowed down by the single PCIe lane and the i5 M 560 CPU, but it is certainly possible. In short, yes you can, but you would probably be better off buying a newer laptop for the same amount.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 24
今までの合計 467
