メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2012年11月2日に発売された第四世代のiPadです。16、32、64GBモデルがあります。モデル番号はA1458です。
error 9 , error 40
Hi , i have an ipad 4 which suddenly showed the apple logo during normal use . when i tried to update / restore i got error 9 , i tried a new lightning port , new battery , tried a restore with reiboot pro . also tried another pc and a macbook for the restore …
I removed the board and used naviplus pro to read the nand chip , seems ok , i also repaired the nand with naviplus and tried to restore again , now i get error 40 . , i’m thinking now may be cpu , is there a test to confirm this ?
..here is a link to the itunes restore log
https://www.dropbox.com/s/3al0q9okudom8e...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
I,m not sure if i’ve made progress with this or not , i gave the nand chip some heat , plugged it into the naviplus again and noticed the model no R/M . box was blank , i filled this in and it restored ok . now i have activation error !!  ,,  its a wifi only model and i tried the restore with pc and a macbook , same result ,...
さんによる
コメントを追加
1 件の回答
all the way at the bottom of the restore log it says this
[19:07:11.7430] Depth:2 Code:40 Error:storage device did not become available
maybe it is your storage device that is bad, and not a cpu.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
so that would suggest the nand chip , i thought that as the naviplus machine was able to read and write to it ok that would rule that out ..
さんによる
コメントを追加
回答を追加する
markparnell1972 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 254
