Touch function doesn’t work
My iPad Pro 9.7” screen is unresponsive. Mid use the touch function just went out. I damaged screen, home button and sleep buttons work but anything touch related is a no go.
what could be the issue?
Well if the screen is damaged I would expect that changing it would fix your problem.
Touch function on ipads is governed by a layer adhered behind the outer glass if the glass breaks there is a high possibility that the touch function will be problematic even if the LCD is ok.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 103
