メインコンテンツにスキップ
2017年6月7日に発売されたFire HD 8の修理ガイドです。この8インチバージョンは1.5GBのRAMとより高速のプロセッサ、HDディスプレイを搭載しています。
22回答 すべてを表示
Can someone please help me locate correct USB charging port?
Can someone please tell me where I can get the correct USB port replacement for this device? I have ordered them off of eBay two separate times now and both times they have been incorrect. If anyone can help me locate the 100% correct charge port I would be very appreciative. It is for the 8th Gen model #L5S83A. Thanks, I have waited too long to fix this tablet already.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Do you have a picture of the charger port top and bottom? I can link you a compatible charger port once I see the pictures.
Is this soldered onto the main logic board or on a small daughter board?
さんによる
コメントを追加
1 件の回答
ベストアンサー
Ben
Unfortunately that link Jayeff posted is to a USB port for the 7th Gen Fire HD 10 USB port. The correct one you need is this: Fire HD 8 L5S83A 8th gen USB port Also if you do a search for USB ports using that model you will find more of the same incorrect ports which you said you already purchased twice already. This is the only one I found that has the correct port pictured. Looks like they used a motherboard to show them matching side by side.
Hope this helps.
Best
Richard
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Yes, that is the correct model. Thanks so much I have ordered one and am glad someone could point me in right direction!
さんによる
Ben
No problem. Glad I could help out. I notice a lot of sellers listing the wrong USB ports and I mean most or almost all of them.
Richard
さんによる
コメントを追加
回答を追加する
BEN さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 7
今までの合計 723
