How do I repair the the touchscreen of the phone?
The touch screen doesn't respond to any sensitive touch
Remove your back cover, battery, sim and memory card. Remove the six screws you can see.
Run something like a credit card around the join of the battery compartment to release it from the rest of the phone.
このアンサーは役に立ちましたか?
David, I believe that you will need a new digitizer. Disassemble your phone and make sure that the cable is connected and that you have no corrosion on your logic board. you can download the complete service manual from here The digitizer is relative inexpensive and available from places like this Good Luck and let us know how it is going
このアンサーは役に立ちましたか?
Do you know that the first touchscreen phone was launched in 1992 by IBM and known as The IBM Simon. Georgia based PDA dimensions developed the only third party application named "DispatchIt" for Simon.It was a Remote Desktop software and costs were $2,999 for the host PC software and $299 for each Simon software client. I found this info in here, http://www.spinfold.com/first-touchscree...
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 11,653
