メインコンテンツにスキップ
An Android smartphone produced by Samsung released in January 2017.
Why is my phone not charging and giving off a burning smell?
I have a Samsing Galaxy A5 (2017). One day it stopped charging and when plugged in, a burning smell is released from the charging port. The other end of the cable also gives off a burning smell. Any solutions, or advice on what I should replace? Also, what is the best adhesive/tape I can use to install the acrylic back after removing it? I’m looking for some adhesive that I can find somewere like bestbuy or walmart.
Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
If my charging port smells like burning how do you stop it from burning
さんによる
My galaxy a01 charger port smells like it's burning and this greasy stuff is on the back of my phone what is it? and what should I do?
さんによる
How do I get it to charge again?
さんによる
コメントを追加
3件の回答
最も参考になった回答
@thestrangeslav something on your charging circuitry went array. You want to go ahead and stop trying to charge it etc. Then you want to go ahead and disassemble your device. Start this by using these guides Samsung Galaxy A5 (2017) and/or this video Then check your circuit boards for obviously damaged components etc. Post some good pictures of your boards with your QUESTION. That way we can see what you see. iFixitでの質問に画像を追加する方法
After that follow the troubleshooting steps as suggested on here
The connector IFC6001 is available at places like this
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
if you smell a burning smell at both ends of the cable try a different USB Adapter and see what it does. on the samsung galaxy a5 it does not use adhesive, the screen just clips in.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Actually this model the screen is held by very strong adhesive. There is also adhesive for the back glass.
It sounds like the USB-C charging socket on the phone needs to be replaced. This is quite difficult to do as it is soldered onto the logic board. This I would leave it to a local reputable phone repair shop to get it fixed.
First thing to do is try another wall charger and cable if you still smell the same electrical burning smell it means the problem is with the charger port instead.
さんによる
go look up a disassembly on a samsung galaxy a5
さんによる
コメントを追加
if you smell burning it was caused by electricity and is melting/ burning something change USB adaptor see if that works if not change the charging board in the phone.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Ayden Aldrich so what's the fix? How can you help the OP repairing his device? How does your answer help the OP?
さんによる
コメントを追加
回答を追加する
David さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 39
過去 30 日: 165
今までの合計 35,807
