メインコンテンツにスキップ
A redesigned Sorento (codename XMA) was launched in South Korea in 2009 as a 2010 model. The second generation was Kia's first model to be manufactured in the United States.
13回答 すべてを表示
Turn signals, windows, door locks, tailgate, high beam
I just have new headlights, bumper and hood installed on my 2014 Sorento. Now my turn signals, power windows, power door locks, tailgate, high beams, and headlights have to be turned on manually… what is going on?! Is there a ground that supports all of this ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
@truax031502 by manually I assume you are saying you have to use the switch whereas before those come on by itself?
さんによる
Yes that is correct, it has an option where the lights will come on by itself or you can twist the knob and turn them on.
さんによる
@truax031502 did you make sure the option is turned on
さんによる
コメントを追加
1 件の回答
最も参考になった回答
@truax031502 make sure that you have the Auto light position turned on.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
David Truax さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 75
