Why is my washer lid locked light flashing?
My washer won’t start, but the lid locked light is flashing. I don’t know what the problem is.
If you are having problems with your washing machine’s lid switch, see the Kenmore 110 Series Washing Machine Doesn’t Stop Spinning When Lid Is Opened problem page for possible causes and solutions.
There are a few reasons why the Lid Locked light may be flashing. Some of those are:
For some troubleshooting start out with these steps:
If all of this checks out then check the lid switch for proper working condition.
Depending on your exact model you want to also check that the Actuator motor is not faulty or has loose wiring
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 30
過去 30 日: 214
今までの合計 16,656
2 件のコメント
Luis Gutierrez is the lid locked? Any laundry in the wash or did that just happen? Unplug your washer and leave it unplugged for a few (5) minutes. then plug it back in and let us know if that made a difference
oldturkey03 さんによる
I have a Kenmore 400 series top load model #23102 washer and the lid is locked and there is a load of clothes inside the washer. I'm not sure what cycle it was in when this occurred. I've unplugged it for hours, plugged it back in, nothing happened. I pushed the start button and the sending light and lid lock light started fleshing. The washer was purchased in 2015. Thank you
lilabnert さんによる
