メインコンテンツにスキップ
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
83回答 すべてを表示
My screen is all white.
It can be charged and turned on and off. However, it stays at a fully white screen. I have already tried pressing the reset button behind but it just turns the screen off. I spilled a tiny bit of water on it yesterday and discovered it today. Is it water damage?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
This does sound like water damage so immediately stop charging the calculator and remove the battery! That way you can avoid accidentally shorting out the calculator and permanently breaking it (I’m hoping that white screen is a software error that can be fixed later). Remove the back cover of the calculator using the teardown guide and dry off the PCB as best you can (make sure to get underneath the aluminum foil). If your calculator isn’t under warranty, then you can go ahead and break the heat melted bits holding the PCB to the front shell. That way you can make sure the front of the PCB, the rubber membrane, and all the buttons are dry.
I’m not an expert at water damage so I would appreciate some guidance from the iFixit community for the following steps.
(As I said above, I’m no expert so this next step may be unnecessary, but it won’t hurt the calculator to do it anyways) From there you should clean everything with at minimum 91% isopropyl alcohol (aka rubbing alcohol) (higher percents are better). Then you should stick everything in rice for several days so any water has time to evaporate. After several days, you can take everything out and just to be safe, clean it all again with the isopropyl alcohol.
Once you’ve put everything back together (let me know if you need help with that), then you can put the battery back in and try to turn it on. If you still get a white screen, try some TI-84 Plus CE Recovery Techniques. If it still doesn’t work properly even after trying that guide, let me know and I’ll have you try some troubleshooting techniques to see if it’s hardware damage.
TI-84 Plus CE Batteryの画像
ガイド
Texas Instruments TI-84 Plus CE Battery Replacement
難易度:
簡単
1 - 5 minutes
TI-84 Plus CEの画像
ガイド
難易度:
簡単
5 seconds - 10 minutes
TI-84 Plus CEの画像
ガイド
TI-84 Plus CE Teardown
難易度:
中レベル
40 minutes
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi Lastmillenial saw this post of yours and I seem to have the same problem with my son’s caculator. I ran through the steps you already provided but no luck, still a white screen b.o. water damage. Is there a way to determine if it’s a hardware issue? Thanks a lot from the Netherlands ?
さんによる
コメントを追加
回答を追加する
kaster hood さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 42
今までの合計 1,109
