メインコンテンツにスキップ
2019年3月に発売。Mac Pro (Early 2009)は、IntelのNehalemアーキテクチャをAppleのプロフェッショナルデスクトップラインに搭載し、2010と2012のCPUアップデートを加えて、インテリアが再設計されたモデルです。
202回答 すべてを表示
DSI510 LED lights going off after attempted GPU upgrade. Help!
I tried to put a AMD Radeon RX 5700 in my 2009 (flashed to 5,1) Mac Pro. I saw online that you can use one of the SATA ports for additional power for the GPU. My mac pro now wont power on. When I power on the Mac Pro, the DSI510 LED lights on the CPU tray, next to both CPU’s light up RED and it wont boot at all. Did I just blow my CPUs? Will buying new ones fix the issue? Help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
@dutch070 how did you do "you can use one of the SATA ports for additional power for the GPU" that?
さんによる
I got a SATA to PCIe 6pin adapter and plugged it into one of the SATA ports on my Mac Pro. That took care of the 6 pin and I did a Dual Mini 6pin to 8pin cable for the 8 pin on the 5700 GPU.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Put the old card back in and see if it runs correctly to help isolate the problem. Flashed cards are always iffy.
What OS X are you running?
このアンサーは役に立ちましたか?
スコア 1
7 件のコメント:
Sorry. I flashed the Mac Pro version from a 4,1 to a 5,1. I didn’t flash the card. Old card already put back in and same issue. I already when through all of the LED diag steps by taking out each part and all seems to be working except for when I put the CPU tray in. The DIMS LEDs are working perfectly fine.
さんによる
Running high Sierra
さんによる
Did you use the DosDude flash or something else? After the flash were things working OK? I flashed my 2009 and am running Sierra. I am running the original nVidia GeForce GT 120 512MG GPU. Do you remember exactly the exact CPU set up you are running and have you ever upgraded or changed it? Can you post a photo of the less that are now showing up?
さんによる
I flashed to 5,1 and was running high Sierra on my 2009 perfect. It was running with the stock 2x2.26 CPUs. Did not upgrade it. It was also the stock (upgraded) graphics card which was the 5870 Radeon 1g. Everything worked great until I plugged in the new RX 5700 with my 2 mini 6pins to 8pin and a SATA to 6pin.
さんによる
Use this guide to post am image of the LEDs you are getting, please:
iFixitでの質問に画像を追加する方法
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Paul さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 8
今までの合計 297
