メインコンテンツにスキップ
This computer was released by Asus in 2014.
20回答 すべてを表示
EeeBook wont boot, not even to BIOS
My EeBook turns on (the screen backlight is visible) but everything else remains black. There is no bootscreen and no BIOS. Multiple attempts at restarting or holding the power button down for longer periods of time give no reliable results.
Trying to enter BIOS with F2 (and many other buttons includings Esc, F8, F10, F11, F12) all yield no results.
Sporadically after many attempts the Laptop does sometimes turn on.
Even though this problem occurs both when plugged in and out, my theory is that this is related to a dying battery.
Any solutions or similar experiences?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
@lufthomas start off with a new battery. Use this guide to replace it
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Firstly try to disconnect all peripheral devices and remove all USB devices and SD media cards.
Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain all residual power and restore default startup settings.
Reconnect the AC power adapter (but do not insert the battery), press the Power button, look for glowing lights near the caps lock and num lock keys, and listen for sounds of a fan or other moving parts turning.
If the computer starts normally after performing a hard reset, you are done troubleshooting.
You can also make a Windows boot media, boot off that, delete all partitions off your drive, start the setup.
Otherwise reading Fix Laptop/Computer Won’t Turn On.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks for the quick reply! I was hoping to avoid the hard reset option since the battery is non-removable on this laptop. Also the computer sporadically does end up starting (although this takes a long time and many attempts). I guess I'll have to do a hard reset then.
Thanks for the help. I'll post an update if the hard reset works.
さんによる
@lufthomas OK, thank you, please feel free to ask if there's any other question.
さんによる
コメントを追加
回答を追加する
Thomas さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 11
今までの合計 1,551
